Compiler error - Syntax
When I try to compile a inherit project I get this error:
c:/st/stm32cubeide_1.17.0/stm32cubeide/plugins/com.st.stm32cube.ide.mcu.externaltools.make.win32_2.2.0.202409170845/tools/bin/sh: syntax error: unexpected "("
make[1]: *** [makefile:92: post-build] Error 2
make: *** [makefile:60: all] Error 2
Can someone please help me? I read that it is something related with the post Build, as I am using b-plus for CAN can it be related?
The error says that there is an unexpected "(" but my IDE is installed in C:// directly
Thank you in advance
HachimBest answer
Hi I finally solved it by copying the post-build of a clean project into mine!
Thanks to all for the reply.
KnarfB
How about your project path and name. Everything should be short and plain ASCII.
Check the indicated lines in makefile: 92
It says post-build, so check for post-build commands
hth
KnarfB
Andrew Neil
Welcome to the forum.
You need to give more detail - please see: How to write your question to maximize your chances to find a solution.
It seems to be an error with your makefile
unsigned_char_array
Lead III
A what?
@Hachim wrote:
I get this error:
How did you get this error? Please share your project.
What is a "b-plus"? And where did you read this? Please share a link.
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
unsigned_char_array
Lead III
@Hachim wrote:
A project that wasn't mine it was from a collegue and i tried to build it in my IDE.
https://drive.google.com/drive/folders/1LRpsyV1rNWEywNoENRjYMPrgeIWA8Nf0?usp=sharing
I cannot open the link. I don't have access.
HachimAuthorBest answer
Andrew Neil
HachimAuthor
Done!
