Change target microcontroller
This is a question about STM32CubeIDE.
When creating a new STM32 project, you select the board, but if I select STM32F412 and edit the program, can I operate the STM32H743 microcontroller?
(We will adjust the pin configuration accordingly)
Andrew Neil
Andrew NeilBest answer
I've moved it to the STM32CubeIDE section, then. And updated the title.
To change the Target microcontroller, See the answer here:
https://community.st.com/t5/stm32cubeide-mcus/how-to-change-hardware-target-on-stm32cubeide-we-have-source/td-p/122794
STTwo-32
Hello @pass3master
Could you give some more details.
Best Regards.$
STTwo-32
Andrew Neil
Thank you for your reply.
We understand that the hardware target cannot be changed,
so we will consider this problem solved.
