May 6, 2025 9:56 AM UTC
Change MPU in existing CubeIDE project?
With an existing Cube Ide project, is it possible to change de Mpu ?
Best regards.
Sébastien
AScha.3
May 6, 2025 10:03 AM UTC
change ...temperatur class T6, T7 ...on same type, same series, same case, of cpu ? yes.
migrate to type compatible other type, same pinout ? yes.
-> In Cube, pinout tab menu -> "list pinout compatible MCUs "  - you can check it there.
change to ...?  Other series, type , pinout ?            No.
Andrew Neil
May 6, 2025 10:12 AM UTC
I edited your post title: Please try to be more descriptive with your title - Just putting "Cube_ide" isn't very informative!
Are you asking about Memory Protection Unit, or a Micro Processor Unit?
Note that this is the Micro Controllers section (Cortex-M) - there is a separate section for Micro Processors (Cortex-A):
https://community.st.com/t5/stm32-mpus/ct-p/stm32-mpus
On changing target MCU:
https://community.st.com/t5/stm32cubeide-mcus/how-to-change-hardware-target-on-stm32cubeide-we-have-source/td-p/122794
https://community.st.com/t5/stm32cubeide-mcus/how-do-i-change-the-mcu-in-cubeide-project/td-p/174138
