Lios
Build Analyzer Problem
hello
i have the
Version: 1.19.0
Build: 25607_20250703_0907 (UTC)
Build Analyzer not working not in auto refresh not in manual refresh
i test every step i found online! nothing
i reinstall the IDE nothing
any idea, or any other way to check flash ram information
thanks
    As I recall, you need to right click the project and Refresh, and then you need to refresh in the build analyzer.
    Also set it to update on request rather than auto.
    Solved: Build Analyzer does not work after STM32CubeIDE up... - STMicroelectronics Community
    Lios
    LiosAuthor
    no...
    i try all this!
    nothing!
    KnarfB
    Same works here as usual, if I select the .elf file and refresh the view.
    If you're still having issues: How to write your question to maximize your chance... - STMicroelectronics Community
    hth
    KnarfB.
