stm32cube VS Code Project Setup STM32F100 device not found
I have followed all the instructions to creating a project in MXCube and importing it into VS Code, however there is no option to select STM32F100VBT6 (Or any MCU in the F1 series for that matter). Is the STM32F1 series not supported?
2025-10-29 17_19_03-Project Setup (RWA_cube) - Untitled (Workspace) - Visual Studio Code.png
Cartu38 OpenDev
Cartu38 OpenDevBest answer
Graduate II
@Marky_Mark STM32F1 like any STM32 device of portfolio is fully supported.
Is your issue related to https://community.st.com/t5/stm32cubeide-for-visual-studio/unable-to-find-stm32h7-in-vs-code-project-setup/td-p/850426 ?
Could you try running the following command in the VSCode integrated terminal:
cube pack sync
Does the process complete successfully? If not, please share the trace.
Cartu38 OpenDev
Graduate II
cube pack sync
Hello @Cartu38 OpenDev , thank you for your reply. I've ran the command you mentioned and here is what it looks like:
2025-10-30 10_28_20-Project Setup (RWA_cube) - Untitled (Workspace) - Visual Studio Code.png
It worked finally after I appended and referenced the contents of the reply to the following:
$hostname = "developer.st.com"
$tcp = New-Object Net.Sockets.TcpClient($hostname, 443)
$ssl = New-Object Net.Security.SslStream($tcp.GetStream(), $false, ({$true}))
$ssl.AuthenticateAsClient($hostname)
$cert = New-Object System.Security.Cryptography.X509Certificates.X509Certificate2 $ssl.RemoteCertificate
$chain = New-Object System.Security.Cryptography.X509Certificates.X509Chain
$chain.Build($cert) | Out-Null
foreach ($element in $chain.ChainElements) {
 Write-Host "----- Certificate -----"
 Write-Host "Subject: $($element.Certificate.Subject)"
 Write-Host "Issuer: $($element.Certificate.Issuer)"
 Write-Host "NotBefore: $($element.Certificate.NotBefore)"
 Write-Host "NotAfter: $($element.Certificate.NotAfter)"
 Write-Host "Thumbprint: $($element.Certificate.Thumbprint)"
 Write-Host ""
 $base64 = [Convert]::ToBase64String($element.Certificate.RawData)
 $pem = "-----BEGIN CERTIFICATE-----`n"
 $pem += ($base64 -split "(.{1,64})" | Where-Object { $_ -ne "" }) -join "`n"
 $pem += "`n-----END CERTIFICATE-----`n"
 Write-Output $pem
solved
Thank you!
