jeffl.kelley9
Oct 17, 2025 1:08 AM UTC
STM32CubeProgrammer not seeing device.
IAR/EWARM can connect to my STM32WL55 nucleo board.  However, I get a complaint about a hardware fault during loading.  It also claimed that the STLINK firmware was old, so I decided to update that.
STM32CubeProgrammer would not initially start, so following directions based on the theory that the JRT was messed up, I reinstalled.
So, cube programmer now starts, but it says not connected.  There is a downward pointing arrow that I can press on without any obvious effect other than a focus box.
Has anyone experienced something similar -- and of course how did you fix it?
Andrew Neil
Oct 17, 2025 11:53 AM UTC
Please show a screenshot of CubeProgrammer - including the full log - when this happens.
Can you still connect using IAR?
See also:
How to solve connection errors when connecting and programming the STM32 target board.
How to solve debugger connection issues
