Feb 1, 2026 5:40 PM UTC
P-NUCLEO WB55 - Arduino setup and basic examples
I am trying to make a basic Enhanced Advertising low power application using Arduino IDE.
I use a standard P-NUCLEO WB55.
I need Arduino IDE because this application is intended to be open for modifications.
The current STM Documentation (https://wiki.st.com/stm32mcu/wiki/Connectivity:STM32WB_BLE_Arduino) is more than one year old and is outdated.
I succeed in lighting the 3 color led by redefining their PIN OUT according with the electrical schematic. But I was not even able to get print messages (I guess the Serial is not properly define for that board).
Where can I found a basic Arduino Example.
I did already the update of the M0 FW which is supposed to be HCI compliant. FUS version V2.2.0.0 and STACK version v1.24.0.3.
Thanks in advance.
Edited to fix link.
Andrew Neil
Andrew NeilBest answer
Feb 3, 2026 5:43 PM UTC
If that's answered your question, please mark the solution.
Please give a link to you thread on the stm32duino forum - so that anyone who finds this can follow it...
Andrew Neil
Feb 2, 2026 4:39 PM UTC
Welcome to the forum.
This forum is focussed on "conventional" development, using things like Keil, STM32CubeIDE, etc.
For Arduino questions, you'd be better at:
https://www.stm32duino.com/
Or the main Arduino forums:
https://forum.arduino.cc/
That doesn't follow at all!
It's perfectly possible to modify applications built using other IDEs.
fbd38Author
Feb 3, 2026 5:03 PM UTC
Thanks a lot. I will continue on the stm32duino forum.
By the way I tried the CubeMX IDE, which is very nice,  but the "entrance ticket" is too high for non-professionals.
Andrew Neil
