STTwo-32
STTwo-32Best answer
Hello @Kaaviya
For such a request, you have to contact our online support team throw OLS.
Best Regards.
STTwo-32
Andrew Neil
That link looks like it is the firmware?
Did you mean the source code?
Are you referring to this: https://www.thethingsnetwork.org/docs/gateways/st/ ?
So this: https://www.st.com/en/evaluation-tools/p-nucleo-lrwan2.html ?
Note that it is Not Recommended for New Designs (NRND):
For firmware, I think you'd have to contact RisingHF - not sure they ever released source?
Also note that it may not be suitable for deployment on a public network:
https://www.thethingsnetwork.org/forum/t/p-nucleo-lrwan2-cant-connect-ttn-server/43067/9#:~:text=Worth%20remembering%20that,further%20away%20could
PS:
https://community.st.com/t5/stm32-mcus-wireless/lrwan-2-gateway-firmware/m-p/793650/highlight/true#M24341
KaaviyaAuthor
the firmware available in this page (https://www.thethingsnetwork.org/docs/gateways/st/) is for eu868. how do i get the firmware for asia923-925MHz to flash in my nucleoF746ZG lorawan gateway
Andrew Neil
You still haven't confirmed that you mean the P-NUCLEO-LRWAN2 gateway?
How to write your question to maximize your chances to find a solution.
STTwo-32
STTwo-32Best answer
Hello @Kaaviya
Best Regards.
STTwo-32
