Visitor II
April 15, 2025
lrwan 2 gateway firmware
  • April 15, 2025
  • 440 views
I’m currently working with the NUCLEO-F746ZG board. Could someone please guide me on where to find the corresponding gateway firmware binary (e.g., st-nucleo-lora-gw-at-fw-v2.0.2.bin) and the setup procedure for getting the gateway up and running?
I am planning to use the loriot.io, please help to find the bin file of that server setup.
Any help or documentation would be greatly appreciated.
Thank you
Best answer by STTwo-32
Hello @NITH and welcome to the ST Community.
The gateway firmware binary is available upon request directly from STMicroelectronics. So, I suggest you contact directly one of our Sales and marketing teams or use our online support system via OLS. As a guide to establish a Communication between your Gateway and Loriot, you may use this video playlist specially the first two videos.
PS: note that this product is not recommended for new designs.
Best Regards.
STTwo-32
STTwo-32
STTwo-32Best answer
Best Regards.
STTwo-32
Andrew Neil
Do you mean P-NUCLEO-LRWAN2:
https://www.st.com/en/evaluation-tools/p-nucleo-lrwan2.html
If so, note that this is NRND (Not Recommended for New Designs):
Also note that it may not be suitable for deployment on a public network:
https://www.thethingsnetwork.org/forum/t/p-nucleo-lrwan2-cant-connect-ttn-server/43067/9#:~:text=Worth%20remembering%20that,further%20away%20could
