Shati.1
Jul 8, 2021 2:03 PM UTC
L073RZ with the expansion do not work with tera term
Hi, i m working with P-NUCLEO LRWAN2 , the gateway is working good, but the L073RZ with the expansion do not work with tera term and don't send any data
Andrew Neil
Jul 13, 2021 10:10 AM UTC
It's not intended to work with TeraTerm (or any other terminal) - it is a standalone node.
This is described in the P-NUCLEO-LORWAN2 documentation.
EDIT
See my post of  January 20, 2021 at 12:05 PM in this thread:
https://community.st.com/s/question/0D53W00000DHlVaSAL/i-want-to-get-pnucleolrwan2-gateway-source
Also my post in this thread:
https://community.st.com/s/question/0D53W00000HMBXUSA5/pnucleolrwan2-sensors-node-does-not-respond-to-at-command-through-a-virtual-serial-tera-terminal
(Sorry, this forum doesn't give links to specific posts :pouting_face: )
Jul 22, 2021 10:20 AM UTC
Hello @Shati.1​ ,
I added this post of @Andrew Neil​ , it contains the fixes proposed by JCOUP.
Hope this helps you !
Imen
Shati.1
Shati.1Author
Jul 22, 2021 1:47 PM UTC
Thank you for your help
Andrew Neil
Jul 23, 2021 10:40 AM UTC
Note that these fixes don't make any difference to the fact that the code does not - and is not intended to - give any output to a local terminal
