How to solve "Error: No STM32 target found!" using Nucleo-WB05kz?
I am getting the same problem with my nucleowb05kz board
Hello @Ankit1810 and welcome to the Community,
It's recommended to create a new thread with relevant information instead of reposting in an old post. This approach increases the chance of the post being reviewed by Community users.
For that, I moved your reply here to a new thread in the relevant forum related to STM32 wireless.
Hi @Ankit1810 ,
Did you check the tips shared in the following article?
How to solve connection errors when connecting and programming the STM32 target board
Ankit1810Author
yes i have tried all the approaches but still getting the same problem
Andrew Neil
Welcome to the forum.
You need to give some more details - please see How to write your question to maximize your chances to find a solution.
In particular:
  • What version of CubeProgrammer are you using?
  • What OS is it running on?
Your screenshot shows that the target is not powered:
See also these Knowledge Base articles:
How to solve connection errors when connecting and programming the STM32 target board.
How to solve debugger connection issues.
Ankit1810Author
i am using CubeProgrammer version 3 and windows os
Andrew Neil
The latest version available is 2.21.0 ?
What Windows version? 32 or 64 bit?
