TA.1
Aug 29, 2023 1:26 PM UTC
How to combine wireless-MBus with LoRaWAN on NUCLEO-WL55J1?
I would like to program the NUCLEO-WL55J1 as a w-MBus concentrator. Getting data from nearby w-MBus sensors and pass it on to the cloud, while I still have the option to switch to LoRa for data transmitting.
Do any of you have an example project, or any guides how to do this.
Issamos
IssamosBest answer
Aug 29, 2023 7:42 PM UTC
Hello again @TA.1
This video is a good start for your application.
Hope this is helpful for you.
Best regards
II
Issamos
Aug 29, 2023 2:23 PM UTC
Hello @TA.1
I suggest you to take a look at the exemples of the wM-Bus in the  X-CUBE-SUBG1. And then try to adapt it to the STM32WL55JC1 using the AN5408.
Hope this is helpful. If this answers your question, please check it as best answer to be diffused.
Best regards.
II
Issamos
IssamosBest answer
Hello again @TA.1
Best regards
II
TA.1
TA.1Author
Sep 6, 2023 1:54 PM UTC
Thank you.
The best way is to buy the stack from Stackforce.
Please see this post. https://community.st.com/t5/stm32-mcus-wireless/setting-up-the-radio-to-sniff-raw-wireless-m-bus-packages/td-p/588367
