May 30, 2025 11:03 AM UTC
B-WL5M-SUBG1 - "Launching LoRaWAN_End_Node has encountered a problem"
Split from https://community.st.com/t5/stm32-mcus-wireless/development-board-for-stm32wl5moc/td-p/795521 as this is a new question.
Hi @STTwo-32 ,
    I have ordered and received two B-WL5M-SUBG1 boards for my testing. I am able to flash one B-WL5M-SUBG1 board. When I am trying to flash the another B-WL5M-SUBG1 board, I am getting this below error. Seems like HW issue or something else? Could you please help me to rectify this issue?
Looking for your valuable response :) .
Thanks,
Praba
Andrew Neil
May 30, 2025 11:24 AM UTC
The message tells you that it failed to initialise the ST-Link.
What ST-Link are you using?
The message also tells you to check power and cabling - have you done that?
More tips on resolving debugger connection problems:
How to solve connection errors when connecting and programming the STM32 target board.
How to solve debugger connection issues
Jun 4, 2025 7:25 AM UTC
I am using STLINK-V3MINIE In-Circuit Debugger And Programmer and also I am using the same power and data cable which I using for the another board. So one B-WL5M-SUBG1 board is working and another B-WL5M-SUBG1 board is not working and getting the above error
