Jtron.11
Senior
Sep 10, 2025 9:03 PM UTC
Update Text and Gauge Needle on multiple custom containers
Hi all,
Can you please give me some pointers how to update the text and needle positions on the custom containers?
I have a gui that has multiple images, exactly the same text and gauge positions.  I created the custom container that has different text fields and one gauge.
With single gauge and multiple text fields on the same view, I am successfully update these peripherals, but when I create multiple copies of the same custom containers I lost, and I don't know how to access the text fields and gauge's needle.
For example:
I created customContainer = 2 text fields and 1 gauge
In then mainView I have customContainer1, customContainer2, customContainer3 and I don't know how to access those text fields and the the gauge.
thank you for your time.
Jtron.11
Jtron.11Best answer
Senior
Sep 12, 2025 12:06 AM UTC
I found a way to implement multiple buttons from this #2 inspiration
https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/multiple-custom-container-with-flexbutton-callbacks/td-p/676921
Then i add the helper function from customContainer base, the confusion is understand how to replicate the customContainer
 //A helper to update text in customContainer header file
 virtual void Text(int val);
//A function in .cpp
void customContainer::updateIntensityText(int val)
 Unicode::snprintf(textAreaIntensityBuffer, TEXTAREAINTENSITY_SIZE, "%d", val);
 textAreaIntensity.invalidate();
 gauge.setValue(val);
 gauge.invalidate();
Jtron.11
Jtron.11AuthorBest answer
Senior
 gauge.invalidate();
Sep 12, 2025 10:52 AM UTC
It looks like found the same solution to update fields inside a custom container as I would have suggested.
Can you explain more about what you now are confused about?
Jtron.11
Jtron.11Author
Senior
Sep 12, 2025 3:57 PM UTC
Hi Peter,
Thank you for checking.  It was a comment that I was confused because of multiple instances of the customContainer but not anymore after I understand the concept.
