Mar 18, 2026 12:41 AM UTC
STM32N6570-DK Board Debug Problem
Hello, I'm using the STM32N6570-DK board.
I completed the TOUCHGFX project through this URL, and there was a DEBUG problem while I was making CUBEMX and CUBEIDE operating it.
(https://community.st.com/t5/stm32-mcus/how-to-debug-stm32n6-touchgfx-applications-using-stm32cubeide/ta-p/845901)
I'm not moving from FSBL to APPLI. I'm asking for your help on this part.
Please check.
jiangfan
Mar 18, 2026 3:45 AM UTC
Please clearly describe what is your problem.
LeeJaewonAuthor
Mar 18, 2026 3:54 AM UTC
When debug is running, fsbl does not go over to the application.
Len_Heske
Mar 18, 2026 7:55 AM UTC
Hello @LeeJaewon,
your FSBL runs normally, right? The problem is going from FSBL to the AppS/AppNS, correct?
Try describing what the context of your problem is:
What is the last thing your FSBL is doing before going to AppS/AppNS. Make sure it's not an FSBL code error that stops you from ever even starting the transition.
How did you setup the transition? Consider providing screenshots or excerpts of your code. (It seems, you attached your whole project folder which is nice but makes it more time consuming for someone to help you troubleshoot. Most people aren't ready to look at an entire project but rather screenshots and excerpts.)
Are there any error messages you could share? What is your debug console saying in CubeIDE?
Are you using developer boot or flash boot? Make sure you correctly loaded all applications into the external flash memory before executing from it.
Kind regards,
Len
