RLein.1
Jul 29, 2022 7:33 PM UTC
Preloading a QSPI with STM32CubeIDE
I'm working on a project using an STM32H753XI MCU with a touch display. I am not currently using TouchGFX. I would like to preload images into the onboard QSPI during the project load. How do I go about doing this? I have used TouchGFX designer on other projects and know this is automated while loading the project onto the PCA.
Pavel A.
Pavel A.Best answer
Jul 29, 2022 9:27 PM UTC
Either you can use the CubeProgrammer with a suitable "external loader", or make a simple utility to copy the data from your PC using semihosting I/O.
The latter is slow, not good for large amount of data.
A small example below:
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/stat.h>
extern void initialise_monitor_handles(void);
void load_stuff(void)
 printf("Semihosting! read big file from host\n");
 initialise_monitor_handles();
 const char * fname = "C:/TMP/stuff.bin";
 // if NO path: opens relative to openocd.exe (.../STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.openocd.../tools/bin/)
 int fd = open(fname, O_RDONLY|O_BINARY);
 if (fd <= 0) {
	 printf("Error open file!\n");
	 return;
 static char buf[4096];
 unsigned offset = 0;
 while (1)
 int rc = read(fd, buf, sizeof(buf));
 if (rc < 0) {
 	 printf("Error read!\n");
 	 break;
 if (rc == 0) {
 	 printf("Read: normal end!\n");
 	 break;
 QSPI_FlashWrite(offset , buf, rc);
 offset += (unsigned)rc;
 printf("Read total: %u\n", offset );
 close(fd);
Pavel A.
Pavel A.Best answer
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
 if (fd <= 0) {
	 return;
 while (1)
 if (rc < 0) {
 	 break;
 if (rc == 0) {
 	 break;
 close(fd);
Andreas Bolsch
Lead III
Jul 30, 2022 7:46 AM UTC
Depends on whether you use CubeProgrammer or OpenOCD inside CubeIDE.
For the former, everything had been said above. For the latter: Use stmqspi driver which comes with OpenOCD. For a sample setup see the cfg-files for stm32h754i-disco.
