Jan 7, 2025 1:32 PM UTC
Using SWD pins to flash code
I am using STM32H503 controller and wanted to understand if SWDIO pin can be used to flash the code.
Andrew Neil
Andrew NeilBest answer
Jan 7, 2025 2:50 PM UTC
Not on its own.
The SWD interface consists of two pins:
  1. SWDIO is the (bidirectional) data pin;
  2. SWCLK is the clock pin.
You need both plus, of course, GND.
https://developer.arm.com/documentation/101636/0100/Debug-and-Trace/JTAG-SWD-Interface
https://learn.sparkfun.com/tutorials/arm-programming/jtag-and-swd
https://kb.segger.com/Target_Interface_SWD
Although not always strictly necessary, you should also include NRST in your debugger/programmer connection - it can get you out of some "bricked" states.
In addition, most debug/programming probes (eg, ST-Link) also want a connection to the target's VDD line.
See the documentation for your debug/programming probe.
See Application note AN5711, Getting started with STM32H5 MCU hardware development:
https://www.st.com/resource/en/application_note/an5711-getting-started-with-stm32h5-mcu-hardware-development-stmicroelectronics.pdf#page=27
Jan 7, 2025 2:44 PM UTC
Yes, the SWD connection is the typical way code is flashed using STM32CubeProgrammer and an ST-Link programmer.
Jan 8, 2025 5:21 AM UTC
Thank you!
Andrew Neil
Jan 8, 2025 9:07 AM UTC
Andrew Neil
Not on its own.
