Nov 12, 2025 12:20 PM UTC
STM32U575 Clock Configuration confusion
Hi team.
I am using STM32U575RIT6  how set the internal and external clock configuration , i have bit confusion can u gide me to resolve this .
thnaks.
Andrew Neil
Nov 12, 2025 12:29 PM UTC
What's the confusion?
Have you tried using CubeMX ?
Nov 12, 2025 12:33 PM UTC
Hello @HA2375-
You can start your project with STM32CubeMX for graphical clock setup.
So, in the Pinout & Configuration view, access the RCC mode panel to enable required clocks, and check the clock setup in the "Clock Configuration" tab.
Make sure to follow the hardware recommendations for crystal placement and board layout described in the User Manual of your board.
How to calibrate the STM32's real-time clock (RTC) - STMicroelectronics Community
HA2375-Author
Nov 14, 2025 11:35 AM UTC
@Imen.D @Andrew Neil   Which port we can use for the External Clock and ,we are not using RTC clock. Can you please suggest the clock selection Hardware point of view . is it correct attached image?
 it
Andrew Neil
Nov 14, 2025 11:53 AM UTC
@HA2375- wrote:
Which port we can use for the External Clock  it
Have you studied the device datasheet ?
That will show you the available external clock options.
See also:
Application note AN5373, Getting started with STM32U5 MCU hardware development.
