STM32U0 Startup current
Hi
Thanks for sharing the info here. I'm really interested in low power MCUs. I do have one question: where can I find information about the startup current draw of this part? The datasheet has very good documentation on the supply current requirements in each low-power modes (6.3.5 Supply current characteristics). But on an energy-harvesting system, the startup current might also be limited. On my STM32L0 based designs, I noticed that the startup current was an order of magnitude higher than when running in low-power mode. Is this also the case on the new STM32U0? Is that documented anywhere?
Thanks!
Javier
