STM32Mx Cube features
Posted on July 13, 2017 at 14:26
While using cube tool I got following questions. Can you please clarify them.
1. In general STM32Mx cube will generate drivers in the location where project file is there with folder structure drivers/STM32F7xx_HAL_Driver/src.
Can we configure path to the generate driver files?
Can we configure the name of the generated folder in the tool?
2. In general STM32Mx cube will generate EWARM settings as well. This is not required on every change.Can we generate only source files without settings?
3. We would like use EmbOS as part of project. We need dynamic memory allocation for graphics . Does EmbOs support for the dynamic memory allocations? Do you have any idea on this point?Thank you
