Nov 24, 2026 5:26 AM UTC
stm32g0b1ney6tr vs stm32g0C1ney6tr,
We have a design built around the STM32G0B1NEY6TR (WLCSP52). Boards fitted with the G0B1 connect over SWD and program normally. Boards fitted with the STM32G0C1NEY6 do not connect over SWD and cannot be programmed.
Going by DS13560 Rev 6, DS13564 Rev 5, ES0548 and ES0549, we expected the C1 to be a drop-in replacement:
- WLCSP52 ballout is identical (MSv63196V3 in both datasheets)
- Same package mechanicals, same DEV_ID (0x467), same REV_ID (0x1000)
- The only errata difference is the RNG
Questions:
1. Is any difference between STM32G0C1NEY6 and STM32G0B1NEY6 relevant to debug access or power-up that isn't in the datasheet or errata?
2. Is running VDD at 1.8 V with VDDIO2 at 3.3 V supported on the WLCSP52 C1, including with PA13/PA14 in the VDDIO2 domain?
3. Do factory-fresh G0C1 parts ship with any option-byte default (e.g. securable memory, BOOT_LOCK, nBOOT_SEL) that differs from the G0B1?
4. Are there known issues or field returns for this part/lot? If yes, what is the failure-analysis / RMA process?
We can provide additional measurements, X-ray images, or sample parts for failure analysis.
The results after opening the package are as follows: The wafer is manufactured by ST, with the ST factory logo printed on its surface. The wafer version is 2020, and the wafer dimensions are 3.08*3.02 mm.
Conclusion: The appearance passes.
1. Visual inspection: The main screen printing (G0C1E6) shows uniform surface texture, with no signs of grinding or secondary coating. The printed characters are clear, and the solder balls show no oxidation or deformation. No traces of secondary ball placement or usage were observed.
waclawek.jan
Nov 24, 2026 7:03 AM UTC
How are all power pins (including VREF+ and VBAT) connected? How are the two VDD supplies sequenced?
I am not ST, these are just blind shots.
