STM32F446: how to run code from externally-attached off-chip SDRAM?
I am currently using the STM32F446ZET6 chip, which comes with 16MB of off-chip SDRAM. I have been trying to run the program in the SDRAM, but have not been successful. I would appreciate any help.
KDJEM.1
KDJEM.1Best answer
Hello @shiyming and welcome to the community;
I recommend you to look at How to set up the FMC peripheral to interface with the SDRAM IS42S16800F-6BLI from ISSI and follow the steps share in this article to configure your project.
Also, you you can get inspired from an available example FMC_SDRAM.  This example describes how to configure the FMC controller to access the SDRAM memory. This application has been tested with STM32446E-EVAL board and can be easily tailored to any other supported device and development board.
I hope this help you.
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Thank you.
Kaouthar
shiymingAuthor
hi,Kaouthar
Thank you for your advice. I will understand and learn from these documents, and try to solve my problem.
If I encounter any problems during this period, please continue to give me your valuable advice
