stm32f429-Disc1
What is the minimum and maximum voltage the internal ADC of stm32f429 can measure ?
    AScha.3
    AScha.3Best answer
    0V  -- 3,3V .
    most other people read in ds of cpu , so i recommend this for you also.
    AScha.3
    GND -- VDDA .
    0V --- 3,3V
    harry123Author
    Minimum and maximum  voltage that adc can take as input
    AScha.3
    AScha.3Best answer
    0V  -- 3,3V .
    Hello @harry123 and welcome to the Community :)
    You mean, input voltage (Vain): Min = GND, max = VREF
    I advise you to check the ADC electrical characteristics (table 74) in the STM32F429x Datasheet.
    Imen
    harry123Author
    If I apply 300mv and check my output the waveform is somewhat distorted and if I apply anything above 1v the waveform is normal
    AScha.3
    i cannot find my big glass ball now, so i cannot see the waveform you talking about . :)
    maybe your source impedance is to high -> use low souce impedance.
    and/or try longer sampling time setting.
    Hi @harry123,
    I moved for you this post to the right topic STM32 MCUs products (instead of Feedback Forum).
    Thanks again for your contribution.
    Imen
