Apr 30, 2024 7:33 AM UTC
STM32F407: PLL is not working
I have build a code of Mcu driver for STM32F407 DISCOVERY board. During Flashing my HSE or HSI works fine but PLL doesn't works on. I will attach the the mcu.c and mai.c file for your reference.
Kindly have a look into this help me out.
waclawek.jan
Apr 30, 2024 9:03 AM UTC
Your coding style is quite hard to penetrate.
You may want to try setting up PLL using straightforward writes to RCC registers, first.
Do you set FLASH waitstates?
May 3, 2024 5:01 AM UTC
Yes, I have set the Flash
Andrew Neil
Apr 30, 2024 9:25 AM UTC
Apr 30, 2024 11:08 AM UTC
Hi @rohitkumarkv07
To ensure that your clock configuration is correct and to isolate the issue with your controller,
Create a new project with CubeMX then enable your oscillator and configure your clock tree.
After that enable an MCO pin to visualize your clock with analyzer/scope.
