piotrek700
May 17, 2013 10:23 PM UTC
STM32F4 Timer External Pulse counting
Posted on May 18, 2013 at 00:23
Since 4 day I'm trying write code which will be able to count external pulses. I tried to use encoder mode but i supposed that this work only with 2 quadrature encoders. I have only one pulse signal and i have no idea how to do it. Could you help me or show examples how to count external pulses using timer?
#counter #timer #off-topic #pulce
May 18, 2013 10:59 AM UTC
Posted on May 18, 2013 at 12:59
This is a blind conversion of a previous example to the Discovery-F4
void TIM3_Configuration(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
/* GPIOC clock enable */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE);
/* TIM3 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
/* GPIOA Configuration: TIM3 CH1 (PC6) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; // Input/Output controlled by peripheral
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; // Button to ground expectation
GPIO_Init(GPIOC, &GPIO_InitStructure);
/* Connect TIM3 pins to AF */
GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_TIM3);
TIM_TimeBaseStructure.TIM_Period = 65535;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_TIxExternalClockConfig(TIM3, TIM_TIxExternalCLK1Source_TI1, TIM_ICPolarity_Rising, 0);
TIM_Cmd(TIM3, ENABLE);
} // sourcer32@gmail.com
m23
May 31, 2013 4:56 PM UTC
Posted on May 31, 2013 at 18:56
My first post here, hi all! :)
I just wanted to say: thak you so much for that code, Clive, I've been struggling with that configuration for 2 days.
Cheers,
Mike
denis
Aug 15, 2013 12:32 PM UTC
Posted on August 15, 2013 at 14:32
My MCU is an STM32F103x, but I made your example work on it too, thanks.
The question I have:
is it possible to have a timer to output clock on one channel and same timer to count external pulses on its other channel?
I.e. clocking on one line, and receiving bits/pulses on the other and counting them.
With example here i only see how to do this with 2 timers.
Aug 15, 2013 1:37 PM UTC
Posted on August 15, 2013 at 15:37
The problem here is that the TIM units have only a single counting element, the channels provide four latches to either compare or hold values with respect to the counter.
denis
Aug 15, 2013 2:07 PM UTC
Posted on August 15, 2013 at 16:07
Yeah, I just thought i give it a shot :)
But using the above pulse counting. Can this be used in a useful way to record PDM ? As in, clock the PDM mic with one timer, and record PDM pulses with the other by configuring it to count the pulses.
Aug 15, 2013 4:05 PM UTC
Posted on August 15, 2013 at 18:05
I don't know, you're wading into an area where I have little practical experience.
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00040808.pdf
I can see ways to generate signals, and measure things with the same timer, you'll have to look at the block diagram to see if the task you want to do is possible.
denis
Sep 4, 2013 12:04 PM UTC
Posted on September 04, 2013 at 14:04
In this external clock source example, what's the behavior of CCR1? I see it's = CNT-1 always for this config, and. .. not sure on why :), i'm not using channel 1 for capture but for clock source.
adapted to TM1 config:
GPIO_InitTypeDef
GPIO_InitStructure
RCC_APB2PeriphClockCmd
RCC_APB2Periph_GPIOA
RCC_APB2Periph_TIM1
ENABLE
GPIOA
Configuration:
TIM1
CH1
PA8
GPIO_InitStructure
GPIO_Pin
GPIO_Pin_8
GPIO_InitStructure
GPIO_Mode
GPIO_Mode_IN_FLOATING
GPIO_InitStructure
GPIO_Speed
GPIO_Speed_2MHz
GPIO_Init
GPIOA
GPIO_InitStructure
TIM_Period
65535
TIM_Prescaler
0
TIM_ClockDivision
0
TIM_CounterMode
TIM_CounterMode_Up
TIM_TimeBaseInit
TIM1
TIM1
0x0
TIM_Cmd
TIM1
ENABLE
Sep 4, 2013 12:23 PM UTC
Posted on September 04, 2013 at 14:23
TIM1 and 8 are special
  /* Main Output (and input) Enable */
  TIM_CtrlPWMOutputs(TIM1, ENABLE);
CCR1 plays NO role
denis
Sep 4, 2013 2:18 PM UTC
Posted on September 04, 2013 at 16:18
mmmm, don't know TIM_CtrlPWMOutputs(TIM1, ENABLE);
would show me.
I wanted to use CCR1 for an interrupt at some counts but it updates at same rate as CNT,
that's why I asked what's it doing.
I can use CCR2 fine.
Sep 4, 2013 2:51 PM UTC
Posted on September 04, 2013 at 16:51
Probably acting in input capture mode, or whatever the default settings are.
/* External input pulse on CH1 */
TIM1->CCR1 = TIM1->CNT;
TIM1->CNT++;
Like I said, I don't think it plays any functional role related to the external count input routing.
