piotrek700
May 17, 2013 10:23 PM UTC
STM32F4 Timer External Pulse counting
Posted on May 18, 2013 at 00:23
Since 4 day I'm trying write code which will be able to count external pulses. I tried to use encoder mode but i supposed that this work only with 2 quadrature encoders. I have only one pulse signal and i have no idea how to do it. Could you help me or show examples how to count external pulses using timer?
#counter #timer #off-topic #pulce
denis
Sep 5, 2013 7:42 AM UTC
Posted on September 05, 2013 at 09:42
Ok clive1 :)
Mar 24, 2014 11:57 PM UTC
Posted on March 25, 2014 at 00:57
Quick port for F1 series parts
void TIM3_Configuration(void) // STM32F1xx
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
/* GPIOC clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO, ENABLE);
/* TIM3 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
/* GPIO Configuration: TIM3 CH1 (PC6) */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE); // Get TIM3 to PC6
TIM_TimeBaseStructure.TIM_Period = 65535;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_TIxExternalClockConfig(TIM3, TIM_TIxExternalCLK1Source_TI1, TIM_ICPolarity_Rising, 0);
TIM_Cmd(TIM3, ENABLE);
} // sourcer32@gmail.com
fireon89
Aug 7, 2014 6:55 PM UTC
Posted on August 07, 2014 at 20:55
/* pulse_counter.phr */
#include ''main.h'' int cnt; void TIM3_Configuration(void); void TIM3_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; /* GPIOC clock enable */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOC, ENABLE); /* TIM3 clock enable */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); /* GPIOA Configuration: TIM3 CH1 (PC6) */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; // Input/Output controlled by peripheral GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; // Button to ground expectation GPIO_Init(GPIOC, &GPIO_InitStructure); /* Connect TIM3 pins to AF */ GPIO_PinAFConfig(GPIOC, GPIO_PinSource6, GPIO_AF_0); TIM_TimeBaseStructure.TIM_Period = 65535; TIM_TimeBaseStructure.TIM_Prescaler = 0; TIM_TimeBaseStructure.TIM_ClockDivision = 0; TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); TIM_TIxExternalClockConfig(TIM3, TIM_TIxExternalCLK1Source_TI2, TIM_ICPolarity_Rising, 0); TIM_Cmd(TIM3, ENABLE); } int main(void) { while(1) { TIM3_Configuration(); cnt=TIM3->CNT ; } } i used this code to count the external pulse , but the counter is not counting . is there any mistakes in the code??
Aug 7, 2014 7:19 PM UTC
Posted on August 07, 2014 at 21:19
You must copy-n-paste better,
TIM_TIxExternalClockConfig(TIM3, TIM_TIxExternalCLK1Source_TI2, TIM_ICPolarity_Rising, 0); // NOT TI2
And don't keep reconfiguring the timer in the while() loop
fireon89
Aug 8, 2014 4:28 AM UTC
Posted on August 08, 2014 at 06:28
Thanks for the guidance Clive1
I moved the timer config statement out of the while loop and replaced TI2 with TI1
but still the counter is not working
I am using STM32f051 eval board
fireon89
Aug 8, 2014 7:46 PM UTC
Posted on August 08, 2014 at 21:46
Hi clive1 ,
I did try using different timer (TIM1) this one showed some response to the external pulse but it counted randomly. I tried to my best to make it count but didn't workout . can I learn how to make it work from you. thanks
#include ''main.h''
int count=0;
void main()
// INTI CLOCK FOR TIM AND GPIO
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
/* TIM1 clock enable */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_2);
TIM_TimeBaseStructure.TIM_Period = 1000;
TIM_TIxExternalClockConfig(TIM1, TIM_TIxExternalCLK1Source_TI2, TIM_ICPolarity_Rising, 0);
TIM_Cmd(TIM1, ENABLE);
while(1)
count = TIM1->CNT;
Aug 9, 2014 4:24 AM UTC
Posted on August 09, 2014 at 06:24
As I don't have a board, try this blind modification
#include ''main.h''
int count=0;
void main()
GPIO_PinAFConfig(GPIOA, GPIO_PinSource9, GPIO_AF_2); // TIM1_CH2
TIM_TimeBaseStructure.TIM_Period = 1000 - 1;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
TIM_CtrlPWMOutputs(TIM1, ENABLE);
while(1)
count = TIM1->CNT;
fireon89
Aug 9, 2014 3:48 PM UTC
Posted on August 09, 2014 at 17:48
Hi Clive ,
I got some example code form the reference manual, and it was working but i was not able to understand these lines.where can I learn to code like this.
GPIOA->MODER = (GPIOA->MODER & ~(GPIO_MODER_MODER9))| (GPIO_MODER_MODER9_1); /* (3) */
//GPIOA->PUPDR = 0x24000000;
GPIOA->PUPDR = 0x1 <<
17
GPIOA->AFR[1] |= 0x2 << ((9-8)*4); /* (4) */
Aug 9, 2014 4:41 PM UTC
Posted on August 09, 2014 at 18:41
If you want to learn register level minutia, then you'll need to absorb all the detail in the Reference Manual, and the bits and functions, and pin level associations. Hours of fun, not a style of programming I would recommend.
vimukthi_0123
Apr 6, 2015 4:17 PM UTC
Posted on April 06, 2015 at 18:17
I cannot figure out why i do not get the external pulse values print in my USART. please help.
float x_dot;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
  /* GPIOA Configuration: TIM3 CH1 (PD12) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_TIM4);
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM_TIxExternalClockConfig(TIM4, TIM_TIxExternalCLK1Source_TI1, TIM_ICPolarity_Rising, 0);
  TIM_Cmd(TIM4, ENABLE);
int main()
char str[120];
SystemInit();
TM_DELAY_Init();
/* Initialize USART, TX: PB6 */
TM_USART_Init(USART1, TM_USART_PinsPack_2, 9600);
while(1){
/* Every 500ms */
if (TM_DELAY_Time() >= 500) {
/* Reset time */
TM_DELAY_SetTime(0);
x_dot = TIM_GetCounter(TIM4);
sprintf(str, ''x_dot- %f\r\n'', x_dot);
TM_USART_Puts(USART1, str);
