dorrachendoul
Apr 10, 2013 12:51 PM UTC
STM32F4 DISCOVERY on eclipse
Posted on April 10, 2013 at 14:51
Am programming an STM32F4 Discovery on eclipse , i staeted with the IO_Toggle example but i got this errors :
Symbol 'GPIO_Pin_15' could not be resolved
Symbol 'RCC_AHB1Periph_GPIOD' could not be resolved
Description    Resource    Path    Location    Type
make: *** [startup_src/startup_stm32f4xx.o] Erreur 1    led_v0             C/C++ Problem
Can someone help me.
Regards,
Dorra
Can someone tell me how to resolve this problem
#no-such-things-as-a-free-lunch
    frankmeyer9
    Apr 11, 2013 1:00 PM UTC
    Posted on April 11, 2013 at 15:00
    Seems you are trying to use CodeSourcery Lite with the Atollic startup file and linker script.
    This may work, as long as you use no libraries (or Atollic versions, too).
    I never tried this combination.
    The whole build output might be helpful here (everything that appears after typing ''make'').
    That would also expand all those ${path} macros.
    dorrachendoul
    Apr 11, 2013 1:07 PM UTC
    Posted on April 11, 2013 at 15:07
    sorry but i couldn't figure out what do you mean exactly, what couls be the problem
    frankmeyer9
    Apr 11, 2013 1:25 PM UTC
    Posted on April 11, 2013 at 15:25
    Me too.
    So I think it is helpful to post all the output that the
    make
    command (or whatever) produces.
    That should be pretty much more than the error lines you posted yet.
    dorrachendoul
    Apr 11, 2013 2:10 PM UTC
    Posted on April 11, 2013 at 16:10
    how can i do that, because am building with eclipse and the only thing that is writting is this line
    make: *** [src/startup_stm32f40xx.o] Erreur 1
    and other errors like :
    Symbol 'RCC_AHB1Periph_GPIOA' could not be resolved
    Symbol 'GPIO_Pin_13' could not be resolved
    frankmeyer9
    Apr 11, 2013 2:24 PM UTC
    Posted on April 11, 2013 at 16:24
    There is a build logfile somewhere. If you are using Linux, be aware that it's probably hidden (starts with a dot, as ''.hidden_name'', for example).
    And, if I remember correctly, there is a possibility to have that output in one of the configurable screens.
    BTW, this is one of the reasons why I don't like Eclipse ...
    dorrachendoul
    Apr 11, 2013 2:29 PM UTC
    Posted on April 11, 2013 at 16:29
    can i use this kind of project with another  environnement instead of eclipse?
    frankmeyer9
    Apr 11, 2013 2:43 PM UTC
    Posted on April 11, 2013 at 16:43
    That's more of a vague question. But yes, you can.
    There are trail version of most commercial IDE's, which are quite convenient to make first steps with ARM Cortex. Dealing with toolchain issues tends to be demotivating for beginners.
    If you like Eclipse, you can try Atollic Truestudio. It is Eclipse-based, and uses a gcc compiler.
    Keil and IAR have their own IDEs and compiler. I have never tried Tasking.
    For all the mentioned toolchains, you find ready-made projects in the Firmware packages provided by ST. Just open the appropriate project file for one of the example projects from the IDE, and that's it (usually).
    Andrew Neil
    Apr 11, 2013 3:37 PM UTC
    Posted on April 11, 2013 at 17:37
    If you like Eclipse and want support, there are paid-for options with CodeSourcery.
    CodeRed also uses Eclipse, and the paid-for version supports STM32, IIRC.
