dorrachendoul
Apr 10, 2013 12:51 PM UTC
STM32F4 DISCOVERY on eclipse
Posted on April 10, 2013 at 14:51
Am programming an STM32F4 Discovery on eclipse , i staeted with the IO_Toggle example but i got this errors :
Symbol 'GPIO_Pin_15' could not be resolved
Symbol 'RCC_AHB1Periph_GPIOD' could not be resolved
Description    Resource    Path    Location    Type
make: *** [startup_src/startup_stm32f4xx.o] Erreur 1    led_v0             C/C++ Problem
Can someone help me.
Regards,
Dorra
Can someone tell me how to resolve this problem
#no-such-things-as-a-free-lunch
    Apr 10, 2013 2:07 PM UTC
    Posted on April 10, 2013 at 16:07
    Sounds like a problem with include files from the library.
    Perhaps your use of stm32f4xx.h, and if it is pulling in stm32f4xx_gpio.h, or stm32f4xx_conf.h
    dorrachendoul
    Apr 10, 2013 2:38 PM UTC
    Posted on April 10, 2013 at 16:38
    i ve alredy resolved the two errors by adding
    stm32f4xx_gpio.h
    stm32f4xx_rcc.h
    but i still have
    What should i do
    frankmeyer9
    Apr 10, 2013 2:46 PM UTC
    Posted on April 10, 2013 at 16:46
    This is a linker error, and it means there is no such symbol (function is missing).
    You need to add (at least) the files:
    stm32f4xx_rcc.c,
    stm32f4xx_gpio.c and
    misc.c
    from folder
    .../<your_STM32F4Lib>/Libraries/STM32F4xx_StdPeriph_Driver/src
    to the project.
    dorrachendoul
    Apr 10, 2013 2:51 PM UTC
    Posted on April 10, 2013 at 16:51
    i have already added them, but i had this error
    Apr 10, 2013 3:03 PM UTC
    Posted on April 10, 2013 at 17:03
    startup_stm32f4xx.s should be an assembler file, I don't know why it would have GPIO code in it. I have seen some C implementations, but this isn't how most of us are using STM32 parts, or developing start up code.
    Do you need to rename it with a ''.S'' instead of a ''.s'', I've encountered a couple of GNU/GCC and makefiles that seem to be dependent on that?
    Open Source solutions generally move the cost burden of support to the user (self supporting), in general you'll need to learn to use the tools, and refer to the documentation.
    dorrachendoul
    Apr 10, 2013 3:10 PM UTC
    Posted on April 10, 2013 at 17:10
    There is no GPIO code on it , i browse it from STM32F4-Discovery_FW_V1.1.0/libraries/CMSIS/ST/STM32F4XX/source/template/truestdio
    and i ve rename it with a ''.S'' instead of a ''.s''
    dorrachendoul
    Apr 10, 2013 3:36 PM UTC
    Posted on April 10, 2013 at 17:36
    i really couldn' t know what should i exactly fix
    dorrachendoul
    Apr 10, 2013 4:26 PM UTC
    Posted on April 10, 2013 at 18:26
    I did the same as this tutorial
    http://shareee.netne.net/wordpress/?p=83
    and i replaces .s with .S
    Why do i get the symbol couls not be resolved  error and
    make: *** [startup_src/startup_stm32f40xx.o] Erreur 1
    Please.
    frankmeyer9
    Apr 11, 2013 9:18 AM UTC
    Posted on April 11, 2013 at 11:18
    There seems to be some issue with your project setup.
    It could be helpful to tell more about your environment (toolchain) apart from just Eclipse.
    I can't open your link, the company gatekeeper views it as a ''threat''.
    Have you tried one of the directly supported toolchains (Keil, Atollic, IAR, Tasking) ?
    dorrachendoul
    Apr 11, 2013 12:23 PM UTC
    Posted on April 11, 2013 at 14:23
    am using gnu arm toolchain, first
    I Set C Compiler’s directories
    ''${workspace_loc:/${ProjName}/startup_src}''
    ''${workspace_loc:/${ProjName}/librarie/Common}''
    ''${workspace_loc:/${ProjName}/librarie/Device/ST/STM32F4xx/Include}''
    ''${workspace_loc:/${ProjName}/librarie/STM3240_41_G_EVAL}''
    ''${workspace_loc:/${ProjName}/src}''
    ''${workspace_loc:/${ProjName}/librarie/CMSIS/Include}''
    ''${workspace_loc:/${ProjName}/librarie/STM32F4xx_StdPeriph_Driver/inc}''
    ''${workspace_loc:/${ProjName}/librarie/STM32F4xx_StdPeriph_Driver/src}''
    than i set
    C Compiler Preprocessor
    USE_STDPERIPH_DRIVER
    USE_STM32F4_DISCOVERY
    STM32F40XX
    i point to “stm32_flash.ld�?: home/user/Bureau/STM324 EVAL/from forum/STM32F4xx_DSP_StdPeriph_Lib_V1.1.0/Project/STM32F4xx_StdPeriph_Templates/TrueSTUDIO/STM324xG_EVAL/stm32_flash.ld
    and finally i created a PATH variables and set it’s value to my CodeSourcery’s bin folder
    but when i run the project i had  this error
    make: *** [src/startup_stm32f40xx.o] Erreur 1
