cagibomber
SPI configuration problem on STM32F4 Discovery
  • August 7, 2012
  • 33 replies
  • 6297 views
Posted on August 07, 2012 at 18:55
Hi everyone,
I am trying to send some bytes of data on a sd-card (8GB) using SPI.
I started with wiring the sd slot and configuring the spi but I have nothing, not even the clock...
I have followed what's explained in the file spi.h and seen other post about spi but I still don't see where I am wrong.
I'd really appreciate if you can help me with it ! Thank you.
#spi-sd-card-stm32-discovery
Cesar cfg
Posted on March 05, 2013 at 12:48
Hi
i am using the stm32f10b eval board and i want to save a text file into a micro sd card ,i know that i should use the fatfs file system but i am not able to integrate the library in my project .
so my question is there a library distinated to stm32f10b or someone who had used it.
thanks
March 5, 2013
Posted on March 05, 2013 at 15:37
I'm not using the F1 commercially and don't have an STM3210B-EVAL. I think it uses the SPI bus to access the cards, and the V3.5.0 library looks to have SPI_SD support code, and projects for the EVAL board.
Cesar cfg
Posted on March 05, 2013 at 16:49
i can not find this library
