SMT32L4xx blocked by bootloader
Hi all,
I'm using stm32l431 and met a problem as below.
After power up a new stm32l431 board which had not been programmed before, the MCU enter bootloader progam and the PC value is 0x1FFF xxxx. Downlaod my own code to MCU but the code and not run.
Then, erase the MCU flash by "STM32Cube progammer", the MCU can work.
BTW, boot0 and RESET pin connect correctly.
