printf not working via ITM_Sendchar, _write never called
I am trying to use SWD for printing using ITM_Sendchar, Printf not calling _write, I tried to put breakpoint and see, But it is not hitting breakpoint
hegde_08_0-1765201262291.pnghegde_08_1-1765201284864.pnghegde_08_2-1765201298919.pnghegde_08_3-1765201309930.png
Tesla DeLoreanBest answer
Clock speed needs to match.
Doesn't the STM32F3 have a default HSI of 8 MHz?
Use that speed.
Perhaps also output to the VCP USART so you can see in a Terminal app, and print out SystemCoreClock to confirm.
KnarfB
By default, stdout is line buffered. You will see output only after a newline '\n'. Less common: stdout buffering might be changed to unbuffered as well.
hth
KnarfB
Andrew Neil
welcome to the forum.
Please see How to write your question to maximize your chances to find a solution - particularly how to post source code (not as images).
See also: How to insert source code
As @KnarfB said, stdout defaults to line-buffered, so you won't see any output until a newline is sent.
This is also noted in the Knowledgebase article, How to redirect the printf function to a UART for debug messages.
See also: https://community.st.com/t5/stm32-mcus/how-to-redirect-the-printf-function-to-a-uart-for-debug-messages/ta-p/49865#:~:text=5.2.%20Line%2Dbuffering,has%20been%20formed - which includes how to disable the line-buffering.
Also Try:
printf( "Hello World!\n" );
instead...
hegde_08Author
I just came here to give update, So _write is called, But now Even though I enabled SWD, and trace, and Port 0, Print is not working
hegde_08_0-1765204062648.pnghegde_08_1-1765204087049.pnghegde_08_2-1765204103898.pnghegde_08_3-1765204122339.png
gbm
Board type? (If ST.) Schematic? (If your own.)
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
hegde_08Author
STM32 , NUCLEO-F303RE
Andrew Neil
gbm
Is the SWO pin configured in CubeMX?
hegde_08Author
How do I check this? any steps would be helpful
hegde_08Author
This is the board I got
Andrew Neil
So check to see if SB15 is open or closed
hegde_08Author
I am new to this, What exactly need to be checked in the board
Use that speed.
hegde_08Author
I was trying not to use HAL Drivers, But surely I will try this once
