kadir ustun1
PB13 PiN of STM32F429 for CAN2
Posted on April 01, 2018 at 19:13
Hello, First of all, I am sorry for my english. Then I am doing a application with CANBUS Protochol. so ı need to use PB13 pin of STM32F429. but when I use this pin, CAN2 is not work. When I look datasheet, this pin is connected VBUS. I set the pin to GPIO_AF9_CAN2, but This is not work still.  Can do you help me?
    April 1, 2018
    Posted on April 01, 2018 at 19:43
    This has to be at least the fourth thread you've opened on this same topic, please don't do that..
    https://community.st.com/0D50X00009XkWXuSAN
    It is not a chip level configuration problem, you need to address the current circuit already implemented on the board (STM32F429I-DISCO). ie remove parts or cut traces.
    kadir ustun1
    Posted on April 01, 2018 at 21:02
    Thank you for your answer. but, I can not solve this problem.
    April 1, 2018
    Posted on April 01, 2018 at 23:04
    So have you looked at the circuit diagram or traced the wire to the components?
