Is Code Sourcery worth the effort ?
Posted on May 28, 2012 at 18:28
I have been using the Atollic (Lite) for my development.
My Atollic Projects work great (doing USB & MMC work). But I have run out of space with the 32K limit. So I moved over recently to the Code Sourcery - or tried. I can compile a simple: main(){while(1){}} program , etc. But when I try to move and compile my Atollic Projects, they do not compile. Simply: make -k all - with no file outputs, warnings, errors, etc. I have been using Eclipse WinArm for Atmel for years. I followed most specs that I could find - on installing Code Sourcery on Eclipse, - but with no result. Is Code Sourcery supposed to work like a Black Box ? Is there some Verbose parameter needed or something ? - Any Advice ? - Does anybody actually promote Code Sourcery ?
