Sep 15, 2025 5:12 AM UTC
Interface Firmware FAILED to reset/halt the target MCU
I am connecting NUCLEO-H743ZI2 to PC via USB, it gives the following error:
The interface firmware FAILED to reset/halt the target MCU STM-32
List possible solutions to the above error.
Amel NASRI
Sep 15, 2025 4:10 PM UTC
Hi @CQT ,
A similar question was asked here. Please refer to it.
The article How to solve connection errors when connecting and programming the STM32 target board may be helpful as well in your case.
-Amel
CQTAuthor
Sep 16, 2025 6:59 AM UTC
Many thanks for the reply, let me check and revert.
Andrew Neil
Sep 15, 2025 4:52 PM UTC
welcome to the forum.
Some more details are needed - please see  How to write your question to maximize your chances to find a solution for best results.
Please describe what, exactly, you were doing when the message appeared.
Show screenshots and/or logs.
What tool(s) were you using - including versions ?
What Host system?
Has the board previously been working?
