I2C timing on STM32u385 Nucleo
- 5 replies
- 1012 views
I am using NCLEO-U385RG-Q running STM32u385. I created a project using the board selector. I configured I2C2 using STM32CubeIDE to run in fastmode at 400khz for PINs PA6/PB2 per schematics described in MB1841. My clock sources are all defaults (see attached) also my calculated timings (attached).
I run the code and the timing doesn't match what I programmed. I am seeing an I2C clock at around 13.158 MHz. Can you please assist?
Thank you
