I2C Loopback using bare-metal code
- 6 replies
- 684 views
Hello All, I am trying to do a loopback test between 2 i2c's on the same board, using bare metal coding and interrupts, and the clk is HSI, 16MHz. How the i2c i configured as slave is failing to acknowledge the address sent by master i2c.
Here is a zip file containing the project.
