I/O logic support at 1.2V for QSPI
we are planning to use STM32H742xI/G controller in our design, we have reviewed the datasheet and need a clarification on the IO logic for QSPI.
Does this controller supports 1.2v IO logic for the QSPI.
KDJEM.1
KDJEM.1Best answer
Hello @saminathan and welcome to the community;
Unfortunately, 1V2 IO logic for QUADSPI interface isn't supported. Please look at this post.
This request is already shared with expert.
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Thank you.
Kaouthar
Hi @KDJEM.1,
Ok as suggestion, we are going to plan to use bi-directional level translator SN74AXC4T245PWR.
Does it work if we use level translator?
Thanks,
Saminathan
KDJEM.1
Hello @saminathan ;
To verify whether it is functional or not, you need to check that the signals required for SN74AXC4T245PWR must be compatible with the QUADSPI signals.
Thank you.
Kaouthar
