Explorer II
Jun 9, 2026 1:09 PM UTC
high measured current from stop 2 mode in stm32l412
Using a custom board with the stm32l412 chip, after entering stop 2 mode, it measures 380uA instead of about 0.72uA without RTC as stated in datasheet.
I know using custom board would get the current consumption to get a bit higher but this is almost ridiculous difference, so I expect that something is off, but not sure where to check.
Thanks in advance.
KDJEM.1
KDJEM.1Best answer
Jun 9, 2026 1:21 PM UTC
Hello ​@Yucef0 and welcome to the community;
Make sure that all free pins as set analog (to optimize the power consumption). For more information, I recommend you to look at How to minimize the power consumption in low power mode: An example using NUCLEO-F401RE board | Community article.
Also, I advise you to look at PWR_STOP2 and check your code.
Please let me know if the issue is solved or not?
Thank you.
Kaouthar
KDJEM.1
KDJEM.1Best answer
Thank you.
Kaouthar
