cai.bai
Sep 12, 2018 7:31 AM UTC
hard fault after configure systick
i use NUCLEO - F767ZI and test a simple code as follow
int sum(int a,int b){
 return a+b;
int main(void){
 int dly;
 __enable_irq();
 SysTick_Config(100000);
 NVIC_EnableIRQ(SysTick_IRQn);
 dly = sum(1,3);
 return 0;
i debug it and when call sum(1,3), it will goto hard fault.
if comment ​NVIC_EnableIRQ(SysTick_IRQn); call and it work fine.
can someone help me ?
waclawek.jan
Sep 12, 2018 7:43 AM UTC
I don't think you are supposed to return from main().
cai.bai
cai.baiAuthor
Sep 12, 2018 7:47 AM UTC
this is example code,actually ,if call NVIC_EnableIRQ(SysTick_IRQn); it will goto hard fault before return;
AvaTar
Senior III
Sep 12, 2018 8:03 AM UTC
Do you have an interrupt handler routine for SysTick, don't you ?
And you have checked in the Map file, or ?
cai.bai
cai.baiAuthor
Sep 12, 2018 8:35 AM UTC
yes,i'm sure SysTick_Handler define correctly
AvaTar
Senior III
Sep 12, 2018 8:45 AM UTC
And implemented + placed correctly ?
cai.bai
cai.baiAuthor
Sep 12, 2018 9:50 AM UTC
yes ,map like
  i.SysTick_Handler            0x08000254  Section    0 main.o(i.SysTick_Handler)
  i.SystemInit               0x08000258  Section    0 system_stm32f7xx.o(i.SystemInit)
  i.__scatterload_copy           0x080002bc  Section    14 handlers.o(i.__scatterload_copy)
  i.__scatterload_null           0x080002ca  Section    2 handlers.o(i.__scatterload_null)
  i.__scatterload_zeroinit         0x080002cc  Section    14 handlers.o(i.__scatterload_zeroinit)
  i.main                  0x080002dc  Section    0 main.o(i.main)
  i.sum                  0x08000358  Section    0 main.o(i.sum)
i think it not about SysTick_Handler, because it goto hard fault before call sum(...)
AvaTar
Senior III
Sep 12, 2018 10:14 AM UTC
And did you evaluate the hardfault reason (SCB regs) ?
Sep 12, 2018 12:59 PM UTC
Really shouldn't need to do that, if you've configured the SysTick it should have the SCB set up.
Remember it is a System Handler, not an IRQ in the broader sense, and the IRQn will be negative
HAL_NVIC_SetPriority() would be usable
Tomas DRESLER
Sep 12, 2018 5:29 PM UTC
How big is the stack and is it defined within reachable RAM? Are other interrupts working well?
Is the VTOR modified in start-up code? It must be aligned or else HF will occur, too.
Tomas DRESLER
Sep 12, 2018 5:32 PM UTC
The NVIC_EnableIRQ doesn't work for SysTick!!!! It doesn't have any Enable or Disable bit within NVIC. Leave all on SysTick_Config(100000); alone.
