cai.bai
Sep 12, 2018 7:31 AM UTC
hard fault after configure systick
i use NUCLEO - F767ZI and test a simple code as follow
int sum(int a,int b){
 return a+b;
int main(void){
 int dly;
 __enable_irq();
 SysTick_Config(100000);
 NVIC_EnableIRQ(SysTick_IRQn);
 dly = sum(1,3);
 return 0;
i debug it and when call sum(1,3), it will goto hard fault.
if comment ​NVIC_EnableIRQ(SysTick_IRQn); call and it work fine.
can someone help me ?
waclawek.jan
Sep 12, 2018 6:02 PM UTC
> The NVIC_EnableIRQ doesn't work for SysTick!!!!
Very well spotted, Tomas! - essentially the same thing Clive said but yes, it's imperative. And the comment at NVIC_EnableIRQ() says that, too.
----- [following is not reply to the original post]
Out of curiosity I had a look at NVIC_EnableIRQ() in the CMSIS headers I'm using for ages (namely
* @file    core_cm4.h
 * @brief   CMSIS Cortex-M4 Core Peripheral Access Layer Header File
 * @version V2.10
static __INLINE void NVIC_EnableIRQ(IRQn_Type IRQn)
/* NVIC->ISER[((uint32_t)(IRQn) >> 5)] = (1 << ((uint32_t)(IRQn) & 0x1F)); enable interrupt */
 NVIC->ISER[(uint32_t)((int32_t)IRQn) >> 5] = (uint32_t)(1 << ((uint32_t)((int32_t)IRQn) & (uint32_t)0x1F)); /* enable interrupt */
Wow. IRQn_Type is an enum and signedness of that is implementation-defined; however, I don't quite get what was the benefit of the double cast (clearly it won't "heal" the improper use with SysTick and other "negative-numbered" exceptions). (In newer CMSIS the commented-out line is omitted.)
I'm apparently not alone: https://github.com/ARM-software/CMSIS_5/issues/248
Sep 12, 2018 7:27 PM UTC
I was perhaps a little too subtle there, herding cats, should have pulled the cattle prod....
It abends because the negative pointer math is super bad.
Pavel A.
Sep 12, 2018 10:36 PM UTC
In more updated CubeMX versions, it says "Value cannot be negative" in comment.
https://github.com/pavel-a/stm32f4_libs/blob/c4560650ddaea6ee33de171027d801a31109565a/STM32Cube_FW_F4/Drivers/CMSIS/Include/core_cm7.h#L1832
GCC compatible compiler even could assert this in compile time ( if (__builtin_constant_p(IRQn) ) _Static_assert (IRQn > 0) ... )
-- pa
waclawek.jan
Sep 12, 2018 10:49 PM UTC
Good idea, but 1. it should be told to ARM as this is in CMSIS; 2. _Static_assert is C11, so I guess this would work only if gcc is run with some of the C11-related -std switch.
