Flash Read and Write Problem
- March 19, 2013
- 11 replies
- 3105 views
Posted on March 19, 2013 at 10:40
I want to display 2 parameters(ID and BD) value on seven segment display. The values will be dynamically changed, so every time I want to write these 2 byte of values on FLASH memory and every power ON or System Reset, I want to Read that values from Flash Memory. Before writing any values if i read the Flash memory, I'm getting some garbage values. After erasing and writing 2 bytes of values to Flash memory, I am not able to read that again. Can anybody help me.... Thanks Selva. #flash-programming #flash-erasing-programming
