ss2
Flash Read and Write Problem
  • March 19, 2013
  • 11 replies
  • 3135 views
Posted on March 19, 2013 at 10:40
     I want to display 2 parameters(ID and BD) value on seven segment display. The values will be dynamically changed, so every time I want to write these 2 byte of values on FLASH memory and every power ON or System Reset, I want to Read that values from Flash Memory.
    Before writing any values if i read the Flash memory, I'm getting some garbage values. After erasing and writing 2 bytes of values to Flash memory, I am not able to read that again. Can anybody help me....
Selva.
#flash-programming #flash-erasing-programming
ss2
ss2Author
Posted on March 21, 2013 at 09:26
Thanks for all your response....I got the solution.
Actually I'm using Flash memory of 128KB, and the flash region is 0x08000000 - 0x0801FFFF
