IVent.1
Senior
February 28, 2024
FILEX rewrite
Hallo,
I'm using U5A9NJQ demoboard with FILEX. I have something that doesn't work, the first time I write on a file, all is correct, but if I rewrite on the same portion of the file, the writing seems to be correct, but, when reading, the content hasn't changed. Do you have found something similar? Is there a project where is possible to have the FILEX working with this demoboard?
Thank you
IVent.1
IVent.1Best answer
Senior
September 6, 2024
The problem was that when I was reading, I wasn't positioned in the correct position with fileseek.
Hello @IVent.1 ,
I advise you to follow this article which guides you on how to use FileX and contains the useful resources:
How to use FileX with eMMC for file system managem... - STMicroelectronics Community
MFARH.1
Hello @IVent.1 ,
Could you please share a code ?
regards,
Maher
IVent.1
IVent.1AuthorBest answer
Senior
September 6, 2024
