May 11, 2026 10:43 AM UTC
Does STM32H563ZIT3Q have Ehternet?
Hi, is anybody able to confirm if the STM32H563ZIT3Q has an ethernet peripheral?
Thanks, regards.
mƎALLEm
mƎALLEmBest answer
May 11, 2026 11:13 AM UTC
Hello @DPB and welcome to the ST community,
As said by @Andrew Neil you need to refer to the datasheet of the product.
STM32H563ZIT3Q
Q means SMPS:
And from this table, its doesn't support Ethernet interface:
You need to use LDO package to have Ethernet.
Hope that answers your question.
Andrew Neil
May 11, 2026 10:57 AM UTC
The datasheet would confirm that?
mƎALLEm
mƎALLEmBest answer
STM32H563ZIT3Q
Q means SMPS:
DPBAuthor
May 11, 2026 11:15 AM UTC
Thanks for your help, much appreciated.
Andrew Neil
May 11, 2026 11:31 AM UTC
If that's answered your question, please mark it as the solution.
