waclawek.jan
Jul 3, 2026 12:13 PM UTC
Can ST please quantify waitstates imposed by accessing ETH registers
ETH is obviously a dual-clock peripheral, and some of the registers are most probably behind a synchronizer, in the MII clock domain. It’s not unlikely that reading some of those registers imposes waitstates. Writing may not, but then those are subject to the Successive write operations to the same register might not be fully taken into account erratum (which hints at the fact that there’s a 4-MII-clock synchronization mechanism, at least for writing).
Can ST confirm or deny, whether reading and/or writing ETH registers imposes waitstates, and in case of yes, can ST please list related registers and also quantify number of waitstates. Here’s why.
In particular, we need this to be quantified for the ‘F4xx, but for other families it would be a bonus to have this, too.
Thanks,
mƎALLEm
mƎALLEmBest answer
Oct 12, 2026 2:06 PM UTC
Hello ​@waclawek.jan and sorry for the late reply.
Just received an answer from our expert confirming that reads and writes to the ethernet registers do not cause wait states. Therefore, no ETH registers are affected, and no additional wait states are needed for register access.
Hope that answers your question.
mƎALLEm
Jul 3, 2026 12:54 PM UTC
Hello ​@waclawek.jan ,
I’ll forward your request internally. I’ll get back to you as soon as I have a feedback.
mƎALLEm
mƎALLEmBest answer
waclawek.jan
Oct 12, 2026 3:38 PM UTC
Hi ​@mƎALLEm ,
Thanks for the info.
PS. Can you please select your post as the answer - I don’t have that option probably because this thread was created in Khoros before the transition.
mƎALLEm
Oct 12, 2026 3:42 PM UTC
Hi ​@waclawek.jan ,
Thank you.
I think better to escalate that issue in Feedback forum. So we could confirm wether the behavior is related to the migration or something else.
waclawek.jan
Oct 12, 2026 6:10 PM UTC
I did.
mƎALLEm
Oct 13, 2026 8:09 AM UTC
From the other post I can see the Best Answer button is showing for you:
Or am I missing something? is that button clickable?
waclawek.jan
Oct 13, 2026 8:14 AM UTC
Oh…. I was looking for it in the menu, as it was in Khoros.
Sorry for that.
