Alexey Vergin
Analog bandwidth of the stm32 ADCs.
  • November 17, 2019
  • 6 replies
  • 2046 views
What is the analog bandwidth of the stm32 ADCs in the different series?
waclawek.jan
Why don't you look up yourself in the respective datasheets?
PS. Change your username to a normal nick.
S.Ma
Principal
November 18, 2019
Datasheet will tell the maximum sampling rate. If the MCU has more than one ADC, there is a SW trick to interleave them to double the sampling rate.
Alexey Vergin
I am going to use the ADC in stroboscopic mode. And I interested in the analog bandwidth, not a sampling rate. This is not the same.
I did not find this information in the datasheets.
waclawek.jan
From analog point of view, the ADC is dominantly a capacitor - the sampling capacitor, capacitance of which is specified in the DS.
The bandwidth is then mostly given by the output impedance of your driving circuit.
Alexey Vergin
Thanks. It`s very important information. But I`m afraid that there are some other factors that may limit the maximum frequency. For example, signal capture time. As far as I understand, it must be principally smaller then the signal period
MasterT
Lead II
November 9, 2023
Probably too late for OP, posting for anyone else getting this topic in the search results.
stm32G474re adc performance - STMicroelectronics Community
