STEVAL-ESC002V1 with NUCLEO-F031K6 board
Hello. I have been researching how to use the STEVAL-ESC002V1 with a NUCLEO-F031K6 board to run a BLDC motor. The documentation mentions using the IAR Embedded Workbench for ARM 8.22, but I am programming with the STMCubeIDE and the MotorControl Workbench 6.3.2. Could someone help direct me on how to do this?
gndLDAuthor
I am currently looking through the Inverter tab after starting a new project in MotorControl Workbench 6.3.2, and I do not see the STEVAL-ESC002V1 listed. Will this be supported?
gndLDAuthor
I have been following this thread and wondering if there has been any solution.
Senior III
I have not used this board but verify if you can use the MCSDK Board Designer software to design this board and generate code.
gndLDAuthor
gndLDAuthor
BTW there are associated software files provided with STSW-ESC002V1 when I look it up online. I just don't know if I can use those files in my STM32CubeIDE firmware.
