Nov 25, 2024 6:51 PM UTC
USBX - Composite USB device - CDC ACM and MSC
I'm trying to develop an application for the STM32H750 using USBX to implement two classes on the same USB device: CDC ACM and MSC. I've managed to get each one working individually, but I'm having trouble combining them. When I connect it to a PC, no driver is assigned to the CDC, although it's recognized as both a mass storage and communication device. Has anyone encountered this issue before? Is there any example I can use as a reference?
FBLBest answer
Dec 13, 2024 8:01 AM UTC
Hi @robertkau
You can check this article using composite dual CDC HID device How to implement the USB device composite class in... - STMicroelectronics Community. You may simply need to redefine MSC class instead of HID class.
Pavel A.
Nov 26, 2024 2:07 AM UTC
Please post a screenshot how it looks in the  device manager. View -> Devices by container.
FBLBest answer
Hi @robertkau
