MEde.1
Mar 6, 2023 9:30 AM UTC
Trying to compile Ultrasound FFT from SW_Source using QT and getting an error message that libhs_datalog.dll is corrupt.
The specific message is LNK1107: invalid or corrupt file cannot read at 0x3F8
shenghua yang
Mar 15, 2023 3:31 AM UTC
Dear ​MEde:
I have the same question to compile Ultrasound FFT from SW_Source using QT and getting an error message that libhs_datalog.dll is corrupt.
How to fixed the bug? Could you help provide any solution?
0693W00000aIyzEQAS.pngThe specific message is LNK1107: invalid or corrupt file cannot read at 0x3F8 shown below.
0693W00000aIyziQAC.pngBest Regards,
Sheng-Hua
shenghua yang
Mar 15, 2023 3:37 AM UTC
Dear ​All:
We have the same question to compile Ultrasound FFT from SW_Source using QT and getting an error message that libhs_datalog.dll is corrupt.
How to fixed the bug? Could any experters help provide any solution?
0693W00000aIyzEQAS.pngThe specific message is LNK1107: "invalid or corrupt file cannot read at 0x3F8" shown below.
Sheng-Hua
MEde.1
MEde.1Author
Mar 16, 2023 9:34 AM UTC
Sheng-Hua,
Unfortunately, I have received nothing from ST since I flagged this with them on 07/03/2023. If you wish to contact them directly feel free to point them to my Case Number 00174143 as well!
SimonePradolini
Mar 31, 2023 10:22 AM UTC
Hi all,
@MEde.1​ , @shenghua yang​  can you share with me both Qt Creator and compiler version are you using?
The package has been tested successfully using Qt Creator 4.10.0 - Based on Qt 5.13.1 (MSVC 2017, 32 bit).
I can check with the version you are using and help you to overcome the issue.
Best regards
Simone
MEde.1
MEde.1Author
Apr 3, 2023 11:57 AM UTC
QT Creator 9.0.2. I wouldn't worry too much I gave up and wrote a python version of your Ultrasound app.
SimonePradolini
Apr 4, 2023 7:55 AM UTC
Ok,
Sorry for the late reply.
FYI: I'm planning a maintenance release for MEMSMIC1 by June, so I'll add the solution for the reported issue into this release.
Best regards
Simone
MEde.1
MEde.1Author
Jun 1, 2023 7:13 AM UTC
Hi Simone,
Well after playing with Python for a couple of months I am convinced of the value of the approach I am taking but now need to refactor into C++ for speed. I don't suppose you could either make available your maintenance version or send me the corrupt .dll?
C:\Users\mikeede\Documents\UltrasoundFFT\SW_source\HS_DataLog\libhs_datalog.dll:-1: error: LNK1107: invalid or corrupt file: cannot read at 0x3F8
MEde.1
MEde.1Author
Aug 10, 2023 1:04 PM UTC
Simone,
So, here we are in August? No sign of a maintenance release.
Cheers,
Mike
Nov 17, 2023 8:00 AM UTC
I got the same issue too. That's so urgent for my company.
Can anyone help from ST? My QT Creator is 5.0.2 from QT 5.12.12.
Nov 17, 2023 12:42 PM UTC
This's my screenshot for your reference. Please ST kindly support this. Thanks in advance.
