Aug 14, 2025 5:04 PM UTC
Stuck at USB Core Soft Reset
I am trying to get USB High Speed running on my board, In the USB Core Soft Reset function, my code keeps on getting stuck in the do while loop that I have shown below. I have went through all the forum posts related to this and there has been no solution that has resolved this issue. The microcontroller series on this board is STM32U5A5RJT6. I would appreciate any guidance. Thank you!
 /* Core Soft Reset */
 USBx->GRSTCTL |= USB_OTG_GRSTCTL_CSRST;
 do
 count++;
 if (count > HAL_USB_TIMEOUT)
 return HAL_TIMEOUT;
 } while ((USBx->GRSTCTL & USB_OTG_GRSTCTL_CSRST) == USB_OTG_GRSTCTL_CSRST);
 return HAL_OK;
Aug 15, 2025 10:58 AM UTC
Hi @smartinez
Did you take a look to this FAQ: Troubleshooting a USB core soft reset stuck?
smartinezAuthor
Aug 15, 2025 2:46 PM UTC
Thank you for your response. Yes, we have taken a look at that article and have tried all of the solutions mentioned, but we will try again. Is there anything else that could be causing the issue?
Thank you so much!
Aug 18, 2025 10:22 AM UTC
Hi @smartinez
I suggest you start with this example.
